Stability Analysis Made Easier 25th June 2021
It was a joy to give a webinar on stability analysis, a feature in JMP that is often not known or is underutilised. Using stability analysis to set expiry dates is a tightly regulated procedure, as evidenced by the EMEA guidelines
In the webinar, I explored:
  • Data Analysis for a Single Batch (Fit Model)
  • Data Analysis for One-Factor, Full-Design Studies (Degradation > Stability Analysis)
  • Data Analysis for Multi-Factor, Full-Design Studies (Degradation > Stability Analysis)
  • Data Analysis For Bracketing Design Studies (Fit Model)
  • Data Analysis to fully elucidate underlying stability mechanisms (Fit Model)
The journal I used in the webinar is attached to this blog post. Do feel free to download the journal - each bullet point corresponds to a saved script in the contained dataset. You definitely can't break anything by working with this data and script, so have a good explore!
Ultimately, JMP is the software to get your products to market quicker; often stability analysis is one of the final hurdles to overcome - make it an easy one!
Here are some further resources on stability analysis within JMP:
Last Modified: Jun 30, 2021 11:33 AM
Comments
ayonika
Level I
Hi @benfrancis ,
Is the webinar recorded and is there a link to access the webinar?
Thanks
gail_massari
Community Manager
Hi @ayonika .  This was not recorded.  The links in the original post by Ben include videos that cover the topic.
Best,
Gail
