What's New in JMP®16 is the latest episode in our Lunch and Learn webinar series. View this recording link to see the newest capabilities and key features in JMP®16, JMP Live and JMP Pro.
Action Recording - Enhanced Log
With the new Action Recording and Enhanced Log Mode, JMP captures activities performed during an interactive session and writes the corresponding JSL code.
Control Charts - Warning Email with JMP® Live
Managing product quality and process improvement effectively, hinges on access to current production data. With the new Control Chart email notifications paired with JMP Live reports, you can monitor production, triage issues and share status.
Model Screening Platform with JMP®Pro
No one model fits every problem. You need the best one to explore the research question. Enter the new Model Screening platform that saves time in the model fitting process.
Make Binning Formula - New Column Utility
The new Make Binning Formula - column Utility allows for interactive binning of continuous data.
Term Selection - Sentiment Analysis with JMP®Pro
Two new features in the Text Explorer platform let you perform data-derived sentiment analysis to better understand what your customer is really saying.
Project Organization - Self Contained File
Projects have been improved to add the ability to save JMP files and reports directly to the project itself. This results in a single .jmpprj file that can be distributed as a single self-contained file.
