Bass Masri's Blog
Bass_Masri
Level VI
Welcome to JMP ®
Learn the basics of JMP® with a series of introductory steps to help get you started.
Situation: You are managing a restaurant and are interested in examining the bill amount by number of guests, day and server.
Task: You need to import a MS Excel worksheet, clean up column variables and then visualize, summarize and explore relationships.
Action: You use the import wizard, column recode, graph builder along with distribution analysis and fit y by x to explore relationships.
Result: You publish reports that identify low balance days, which you share interactively with your team so that improvements can be made.
Next Steps: As a result of your analysis, a marketing campaign improves your restaurants revenue and you are promoted to region operations manager.
https://www.jmp.com/en_au/jmp-trial/learn-the-basics-of-jmp.html
Last Modified: Nov 15, 2021 4:30 PM
