Bass Masri's Blog
Bass_Masri
Level VI
Health and Life Science
Health and Life Science using JMP®
Healthcare and life sciences are some of the largest and fastest-growing industries in the world. Rapid convergence of the healthcare, life sciences and technology sectors require even more expertise in data management, graphical techniques, statistical methods, predictive models and ways to share findings. We use the following clinical research case study to outline these life saving analytical methods.
Situation: You are a new clinical research manager and are interested in examining the weights of patients by gender.
Task: You need to import a MS Excel worksheet, clean up column variables and then visualize, summarize and explore relationships.
Action: You use the import wizard, column recode and graph builder along with distribution analysis and fit y by x to explore relationships.
Result: You publish reports that identify significant differences, which you share interactively with your team so that improvements can be made.
Next Steps: As a result, a new clinical trial improves your patients weight and you are promoted to the director clinical operations.
Last Modified: May 17, 2022 8:07 PM
