- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Get Direct Link
Setting License File Location within Preferences using JSL script
I manage the JMP license file for my companies users in the UK. Every year the location of this file is slightly different and I have to send out detailed instructions how to change this location ( file - Preferences- File locations - License file path and paste the link into the box that appears). this seems to be beyond some users and each year it takes a lot of my time to sort this out for them.
Is there a way to run a jsl script that will automatically change this within their preferences? the closest I can find is this How to access System Preferences in JSL, specifically the date format setting but it doesn't really help my issue.
So what I'd like is a jsl file that is run that changes the License file path within preferences.
Regards
David
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: Setting License File Location within Preferences using JSL script
You can do what you want by using Set Preferences
Set Preferences(
File Location Settings(
Installation Directory( "C:\Program Files\SAS\JMPPRO\15" ),
License File Path( "C:\PROGRAM FILES\SAS\JMPPRO\15\JMP.PER" )
Note: You may have to set all of the File Location Settings that are on ones system all at once, so that you do not delete any existing File Location Settings. So you may have to first
thePrefs = Get Preferences(File Location Settings );
to get all of the File Location Settings, replace the License File Path, and then apply the Set Preferences.
