Share your analytics insights with fellow JMP users. Submit a brief abstract to the Discovery Europe call for content describing innovative ways you use JMP.
View Original Published Thread
JMP Pro Silent installation issues
CSUF
Level I
I am getting the below error in the log file when I try to run an unattended installation of JMP Pro 13
- I build a responce file by running "setup.exe /r" and walking through the installation (Defaults), Reponse File below
- I have loaded all dependences on the mahcines (.NET Framework 4.6.2, Microsoft Visual C++ 2010, Microsoft Visual C++ 2013, Microsoft Visual C++ 2015) all latest versions
- I ran the below silent installation commands (setup.exe /A /Z /S "Setup.iss") (setup.exe -s "Setup.iss") (setup.exe /A /Z /S /f1"Setup.iss") and I just get the[ResponseResult] ResultCode=-5 in the log file.
Thoughts?
LOG FILE
___________________
[InstallShield Silent]
Version=v7.00
File=Log File
[ResponseResult]
ResultCode=-5
___________________
REPONSE FILE
___________________
Version=v7.00
File=Response File
[File Transfer]
OverwrittenReadOnly=NoToAll
[{4DC2278F-75CE-4316-A76B-F5206C1CEE02}-DlgOrder]
Dlg0={4DC2278F-75CE-4316-A76B-F5206C1CEE02}-SdWelcome-0
Count=5
Dlg1={4DC2278F-75CE-4316-A76B-F5206C1CEE02}-SdAskDestPath-0
Dlg2={4DC2278F-75CE-4316-A76B-F5206C1CEE02}-SdComponentTree-0
Dlg3={4DC2278F-75CE-4316-A76B-F5206C1CEE02}-SdStartCopy2-0
Dlg4={4DC2278F-75CE-4316-A76B-F5206C1CEE02}-SdFinish-0
[{4DC2278F-75CE-4316-A76B-F5206C1CEE02}-SdWelcome-0]
Result=1
[{4DC2278F-75CE-4316-A76B-F5206C1CEE02}-SdAskDestPath-0]
szDir=C:\Program Files\SAS\JMPPRO\13
Result=1
[{4DC2278F-75CE-4316-A76B-F5206C1CEE02}-SdComponentTree-0]
Language0-type=string
Language0-count=1
Language0-0=Language0\English
Component-type=string
Component-count=4
Component-0=Program Files64
Component-1=RootLevel64
Component-2=Language0
Component-3=Imagemaps
Result=1
[{4DC2278F-75CE-4316-A76B-F5206C1CEE02}-SdStartCopy2-0]
Result=1
[Application]
Name=JMP
Version=13.0
Company=SAS Institute Inc.
Lang=0409
[{4DC2278F-75CE-4316-A76B-F5206C1CEE02}-SdFinish-0]
Result=1
bOpt1=0
bOpt2=0
___________________
3 REPLIES 3
ian_jmp
Level X
Re: JMP Pro Silent installation issues
Best to contact support@jmp.com if you haven't already.
The ResultCode=-5 indicates that the ISS file is not found.  The ISS file itself looks fine.  Be sure to make note of where the ISS file was created.  If you do not specify a location when you create it, it will be created in c:\windows.
To install JMP using silent setup, run the setup command with noting the specific location of the response file.
          setup.exe -s -f1{response file name}
Note that there is "NOT" a space between the -f1 parameter and the file name. For example, if you created the a silent script file named jmpsilent.iss in C:\scripts , execute the following statement:
          setup.exe -s -f1c:\scripts\jmpsilent.iss
 Reference http://www.jmp.com/support/notes/8/135.html for more information.
- Bob Hickey
CSUF
Level I
Thanks for the reply.  I have my .iss file in the root of C:\ and I am running this command from the installation directory (setup.exe -S f1C:\Setup.iss) also tried (setup.exe -S f1"C:\Setup.iss") and nothing happens and my log file is still showing a result code of -5, see screenshot below
______________
Version=v7.00
File=Log File
[ResponseResult]
ResultCode=-5
______________
