Share your analytics insights with fellow JMP users. Submit a brief abstract to the Discovery Europe call for content describing innovative ways you use JMP.
Ryan_Gilmore
JMP 17 Macintosh Install
There is a known issue when installing JMP and JMP Pro 17.0 for MacOS via the SAS Software Depot. For more information, please read The JMP® 17 installation media for Macintosh does not apply the license file
1 REPLY 1
statman
Re: JMP 17 Macintosh Install
What if you already installed JMP and did not have the SID file with the dmg file?  I think you can run the script:
renew license();
And locate the SID file.
