I wrote a script in JMP that utilizes R to help a client get some specific information out of their dataset. They had never installed R before so I helped them get it installed (much as I have dozens of times). My script throws an error if JMP cannot find R on the computer (it utilizes a Throw(rconn = R Connect();,...) statement). JMP was running when R was installed, I ran the script and it couldn't find R. I quit JMP, relaunched it - same error. I rebooted the computer, ran the script - same error. I uninstalled R, quit JMP, installed R, launched JMP - same error. So, what I'm wondering is, can I help JMP find R by specifying the destination? JMP Support files say:
How JMP Finds R
JMP delays loading R until a JSL-based script requires access to it. When JMP needs to load R, it follows the standard steps for finding R on a Windows computer:
1.Look up the environment variable R_HOME.
If the variable exists, load R from the specified directory.
2.If the environment variable R_HOME does not exist, look up the InstallPath value in the Windows registry under the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\R-core\R
For 32-bit JMP running on a 64-bit machine, the InstallPath value is under the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432NODE\R-core\R
If the InstallPath value exists, load R from the specified directory.
3.If the InstallPath value does not exist, an error message states that R could not be found.
Can I specify the environment variable R_HOME or pass along the InstallPath value?
