JMP is fast. Its interface is designed for ease and efficiency, and its algorithms under the hood are lightning quick. In fact, many users adopt JMP because it empowers them to make data discoveries with exceptional speed. But much like a souped-up car goes fastest when paired with a skilled driver, JMP operates at its fastest when paired with a user who knows how to “drive” it efficiently. Join Ross Metusalem, JMP Senior Academic Ambassador, to learn strategies for boosting your speed using JMP, including shortcuts, time-saving features, and best practices for efficiency, all of which are relevant to all users, no matter your domain or experience level. By the end, you’ll be on the road to maximizing your speed as a JMP user. Multiply that by JMP’s inherent speed as a data discovery tool, and you’ll be making discoveries with speed squared.
