Wasatch Front JMP Users Group Discussions
Open to all JMP users in Salt Lake City, UT area
gail_massari
See JMP in action. Friday webinars and JMP journals, files and videos help you practice after the demo.
Some of you already attend Mastering JMP sessions.  Spread the word to your colleagues and if you have never attended, please try attending one!
Our Systems Engineers use case studies to demo some tools to tackle your work, research or academic challenges using JMP.  Ask questions during the webinar to help clarify if and how the techniques may apply to your situation. Then, after the live demo, view the demo video and download the JMP Journals and files to try the techniques yourself.
Register for upcoming webinars
Essentials of Designing Experiments Using JMP - September 19, 2019 | 2 p.m. ET
See how to design a controlled set of tests to model and explore the relationship between factors and one or more responses. See two case studies that demonstrate how to build, model, refine and interpret results.
Unlocking the Power of Graph Builder - September 20, 2019 | 2 p.m. ET
Learn to use advanced features to control format and appearance to create persuasive visualizations. See several case studies that demonstrate different techniques to create compelling graphs that uncover relationships in your data and identify areas for further analysis.
Using Blocking When Designing Experiments - September 24, 2019 | 2 p.m. ET
See how to use JMP DOE tools to increase accuracy by controlling for sources of variability (blocking factors) that are not of primary interest to the outcome. Learn about blocking types, when and how to use them, and situations where they may be useful.
Creating, Using and Sharing Journals - September 27, 2019 | 2 p.m. ET
Learn how to format journals; dynamically open reports and tables; and interact with tables and report entries by selecting points, subsetting data, or using context-sensitivity to create more reports and graphs.
JSL for Building Interactive Dialogs for Automated Workflows - October 4, 2019 | 2 p.m. ET
See how to run reports, capture the report scripts that JMP automatically generates, and reuse the scripts to rerun the reports. Learn how to implement the next step in automating a workflow - running the scripts from a customized dialog that allows the user to select specific data tables, columns or row ranges.
Questions?  Feel free to be in touch with me @gail_massari
0 REPLIES 0
