  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Uncharted
Craige_Hales
Wild Road Map
JSL, attached below, modified a bit to make this video.  Best when viewed.  Intended for full screen.  Inspired by Substrate screensaver.
this is a typical picture from the attached JSL.
Last Modified: Nov 14, 2016 4:36 AM
Comments
Hui_Di
Fantastic!
Jordan_Hiller
Wow Craige, you just turned JMP into a screensaver. What's next -- flying toasters?
Craige_Hales
Thanks!  I was thinking about a scroller built with transparent bitmaps.
atlas100
Level III
Great script! I don't see where in the code curved lines are generated. Is there a way to generate more curves?
I'm new to JSL.
Thank you.
Craige_Hales
Thanks! In my excitement to post, it looks like I forgot to write comments!
This program is using a JSL list named stack (which is misnamed, but ignore that.) Stack holds a list of active roads. Each element on the stack is a list of
  • the last row,col location of a pixel in the road
  • the last angle the road was headed
  • the delta angle the road turns as each pixel is drawn
There is also a veclen, which I believe is always .7, close to .707.
The driver loop, near the end, calls the doodle function N times with indexes to the N front-most items in stack. doodle draws one pixel for each of those roads, so it looks like N roads are built at the same time. Look at the code at the front of doodle and you'll see the code that implements the turn:
1	{row, col, angle, deltaangle, veclen} = stack[istack];
2	{newrow, newcol, angle} = Eval List( {row + veclen * Sin( angle ), col + veclen * Cos( angle ), angle + deltaangle} );
3	If( newrow >= 1 & newrow <= rowsiz & newcol >= 1 & newcol <= colsiz,
4		stack[istack] = Eval List( {newrow, newcol, angle, deltaangle, veclen} );
Line 1 grabs the state of the nth (istack) road. Line 2 computes a row and col for the next pixel AND a new angle (for next time.) Line 3 is testing if the row,col is still on the screen, and if so, line 4 updates the info for the road back into the stack.
If you are still following in the source, you'll see a black pixel set at row,col, or if off screen, you'll see the stack element removed...which will make a new road, further down the stack, start drawing next time.
You'll also see code that spawns new roads at right angles (by adding +/- pi/2 to the current angle), and code that sprays the lightly colored sand at right angles as well.
The code that spawns a new road
// new doodle at right angle
stack[N Items( stack ) + 1] = Eval List({newrow, newcol, angle + If( Random Integer( 0, 1 ), Pi() / 2, -Pi() / 2 ), Random Normal( 0, .0001 ), .7});
is the answer to your question: random normal is generating a delta angle that is very close to zero, most of the time. Make the .0001 a shade larger and more of the lines will have more curvature.
Thanks for puzzling over the code, and ask again if the missing comments are a problem.
atlas100
Level III
Thank you for the fast reply. I've had lots of fun generating images with different curvature and color combinations.
