JMP will suspend normal business operations for our Winter Holiday beginning on Wednesday, Dec. 24, 2025, at 5:00 p.m. ET (2:00 p.m. ET for JMP Accounts Receivable).
We’re retiring the File Exchange at the end of this year. The JMP Marketplace is now your destination for add-ins and extensions.
Thanks! In my excitement to post, it looks like I forgot to write comments!
This program is using a JSL list named stack (which is misnamed, but ignore that.) Stack holds a list of active roads. Each element on the stack is a list of
the last row,col location of a pixel in the road
the last angle the road was headed
the delta angle the road turns as each pixel is drawn
There is also a veclen, which I believe is always .7, close to .707.
The driver loop, near the end, calls the doodle function N times with indexes to the N front-most items in stack. doodle draws one pixel for each of those roads, so it looks like N roads are built at the same time. Look at the code at the front of doodle and you'll see the code that implements the turn:
Line 1 grabs the state of the nth (istack) road. Line 2 computes a row and col for the next pixel AND a new angle (for next time.) Line 3 is testing if the row,col is still on the screen, and if so, line 4 updates the info for the road back into the stack.
If you are still following in the source, you'll see a black pixel set at row,col, or if off screen, you'll see the stack element removed...which will make a new road, further down the stack, start drawing next time.
You'll also see code that spawns new roads at right angles (by adding +/- pi/2 to the current angle), and code that sprays the lightly colored sand at right angles as well.
The code that spawns a new road
// new doodle at right angle
stack[N Items( stack ) + 1] = Eval List({newrow, newcol, angle + If( Random Integer( 0, 1 ), Pi() / 2, -Pi() / 2 ), Random Normal( 0, .0001 ), .7});
is the answer to your question: random normal is generating a delta angle that is very close to zero, most of the time. Make the .0001 a shade larger and more of the lines will have more curvature.
Thanks for puzzling over the code, and ask again if the missing comments are a problem.
