This JSL was inspired by some gray scale images by Misha Friedman. His images are better.
12345678
There's no real 3D here, the perspective is odd, it is just a toy for a rainy Saturday. The attached JSL is set up to generate images into a directory. I picked a few of the better ones and cropped them a bit. The JSL is not optimized; each picture takes a minute or so to render.
horizon1.jsl
Last Modified: Feb 23, 2019 10:12 PM
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
