Uncharted
Craige_Hales
Progress Bar
Re: Does JSL provide a "busy" indicator similar to a spinning wheel or bar?
here's an example of a progress indicator made in JSL; it uses a namespace to encapsulate the code.  The last few lines are a test, try setting workload ​bigger or smaller.  For smooth performance the progress:set function must be called fairly often. The progress:init function needs to know the total amount of work that will be done to get the percentage right.
Edit: attached a copy of the JSL, apparently the inline JSL may not display correctly.
progress = New Namespace(
	"progress"
progress:init = Function( {workload},
	progress:TotalWork = workload;
	progress:Current = -1;
	progress:tick = Tick Seconds();
	progress:Window = New Window( "progress",
		H List Box(
			Spacer Box( size( 20, 20 ) ),
			progress:busy = Busy Light( <<size( 60, 60 ) ),
			Border Box( Left( 20 ), Right( 20 ), top( 20 ), bottom( 20 ),
				H List Box(
					progress:left = Spacer Box( color( RGB Color( 20, 200, 20 ) ) ),
					progress:right = Spacer Box( color( RGB Color( 100, 100, 100 ) ) ),
					Spacer Box( size( 20, 10 ) ),
					progress:text = Text Box( "0" )
	progress:set( 0 );
progress:set = Function( {workdone},
	{now = Tick Seconds(), pct = Round( 100 * workdone / progress:TotalWork )},
	If( now - progress:tick > 1 / 30,
		progress:tick = now;
		If( pct != progress:Current,
			progress:Current = pct;
			progress:left << size( progress:Current, 20 );
			progress:right << size( 100 - progress:Current, 20 );
			progress:text << settext( Char( pct ) || "%" );
		progress:busy << advance;
		Wait( 0 );
progress:term = Function( {},
	progress:Window << closeWindow
// test
workload = 1e6; // 1e6 is about 5 seconds
progress:init( workload );
For( i = 1, i <= workload, i++,
	progress:set( i )
progress:term();
Last Modified: Oct 25, 2018 9:48 PM
Comments
frank_wang
Level IV
Hi Craige
Thanks for your sharing about progress bar.
I 'd like to monitor how many files has been processed with progress bar.
So that, my "Workload" is not about 'time' but 'Count'. (N files in folder)
Is that mean I should delete "progress:tick" and the sentence
Could you give me some advises.
Thanks.
Craige_Hales
Good question.
The test you are asking about is designed to prevent updating the display more than 30 times per second, which would be a waste of time. In fact without that test, the example would update the display a million times and take a very long time to run.
The example assumes there are 1e6 files. You should write a loop similar to the last 6 lines of code, doing your file processing just before progress:set(i). And change the 1e6 to your number of files.
