Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
Transforming Data to Make Better Predictions
Presented in English
Published on ‎11-07-2024 03:29 PM by Community Manager Community Manager | Updated on ‎08-26-2026 11:52 AM
See how to:
  • Understand why transformations stabilize variance, make the error more uniform across the design region, remedy lack of fit and plot predictions in a way that does not violate physical limits, display negative counts or erroneously report yields as greater than 100%donn
  • Transform data on the fly using Graph Builder and change scales to improve graph readability and interpretability
  • Use square root transformation to eliminate negative values and examine how using Box-Cox power transformation on response might change fit
  • Compare no transformation, log transformation with prediction in raw units and log transformation with prediction in log units
  • Use square root transformation to construct model effects using Polynomial to Degree 2 macro, identify best transformation, use selected transformation, save residuals to data table and evaluate results using distributions
  • See how square root transformation might display a more uniform count spread and more linear relationship
Why Transforrmations Can Be UsefulWhy Transforrmations Can Be UsefulWhy Transforrmations Can Be Useful
Start:
Thu, Sep 24, 2020 02:00 PM EDT
End:
Thu, Sep 24, 2020 03:00 PM EDT
0 Comments
