Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
Organizing and Getting the Most from JMP® Tables
Published on ‎11-07-2024 03:29 PM by Community Manager Community Manager | Updated on ‎04-08-2025 09:12 AM
See how to:
  • Create, format and navigate rows and columns from data grid and table panel
  • Use column properties to set data types (numeric, character, row state, expression) and modeling types (continuous, ordinal, nominal, multiple response, unstructured text, vector)
  • Understand the way JMP analyzes data based on data and modeling types
  • Use multiple response character data; hide and/or exclude rows and understand what each means
  • Use red triangle hot spots to sequentially disclose analysis and formatting options
  • Group table script to organize them in table panel
  • Format columns
  • Understand the Distribution column exception related to incorrect data or analysis type
  • See how JMP graphically links multiple response data on some graphs to show relationship between values
  • Use shortcuts to move between graphs and reports
  • Save replayable analysis scripts to data table panel
  • Add metadata (notes, list check, value labels, value ordering, formula, formula preview results)  to a group of columns
  • Recode in place to new column; save recode formula to auto-update column when new observations are added; group similar values to same recoded value; recode to value labels to simplify graphs
  • Subset rows from graph to new unlinked data table; use data view to subset rows linked to data table; exclude data from report using local data filter; label individual rows for displaying in all graphs
Note: Q&A included at times 10:52, 34:35 and 42:21.
In this short video, Alisa Hunt-Lowery shows how to compare data tables using the JMP 16 enhanced interface:
Resources
Start:
Thu, Sep 24, 2020 02:00 PM EDT
End:
Thu, Sep 24, 2020 03:00 PM EDT
Labels (1)
0 Comments
