Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
Identifying Unusual Patterns that Might Indicate Data Integrity Issues
Presented in English
Published on ‎11-07-2024 03:28 PM by Community Manager Community Manager | Updated on ‎11-08-2024 08:07 AM
See how to:
  • Explore Patterns
  • Identify duplicate values
    • Find Most Duplicated Values - values that appear most frequently within column
    • Find Longest Runs - values that repeats in consecutive rows within column
    • Find Longest Duplicated Sequences- sequence of values that repeats within column
    • Find Duplicates Across Columns- sequence of values that appears in the same rows across multiple columns
    • Use Rarity Score to interpret duplications
      • Conceptually a pattern is about as likely as getting [rarity value] heads in a row when flipping a fair coin
      • Statistically, -Log2(p);  where p is probability of pattern assuming random ordering of values
  • Identify unusual values
    • Locate Formatted Width within cells - both overall and decimals
    • Locate suspicious Fraction Lengths
    • Locate suspicious Leading Digits that are too uniform
      • Check distribution of leading digits against Benford's Law, which says, that in many naturally occurring groups of numbers, distribution of leading digit is not uniform
      • Log10( (d+1) / d), where d is leading digit
  • Identify unexpected linear relationships where, within some group of consecutive rows (default is 10), one column has an exact linear relationship with another column
  • Identify specification limit anomalies for columns with spec limit properties
    • Locate Spec Limit Matches where limits in cells exactly match LSL or USL
    • Compare Spec Limits Distribution to compare out-of-spec values to expected out-of-spec values
Resources:
Start:
Wed, Jun 17, 2020 02:00 PM EDT
End:
Wed, Jun 17, 2020 03:00 PM EDT
0 Comments
