This website uses Cookies. Click Accept to agree to our website's cookie use as described in our Privacy Policy. Click Preferences to customize your cookie settings.
Now Functional DoE is even easier: 5 minute example from JMP Pro 15
Nov 29, 2019 10:58 AM
You have seen before how you can better understand your processes with Functional Data Explorer in JMP Pro. Now Functional DoE analysis is even quicker and easier in JMP Pro 15.
Great way to see how to interpret JMP Pro 15 Score Plot and Functional Principal Component Profiler to see, in this case, how low score shows a steep decline in the curve and a high score means more gradual decline. From within Functional Data Explorer, one can model the functional response as a function of the designed experiment factors to explore how to set them to yield the desired functional response to improve process, cut costs and get product to market faster.
Score Plot and FPC Profiler for functional data analysis
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
