Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
Now Functional DoE is even easier: 5 minute example from JMP Pro 15
Nov 29, 2019 10:58 AM
You have seen before how you can better understand your processes with Functional Data Explorer in JMP Pro. Now Functional DoE analysis is even quicker and easier in JMP Pro 15.
Great way to see how to interpret JMP Pro 15 Score Plot and Functional Principal Component Profiler to see, in this case, how low score shows a steep decline in the curve and a high score means more gradual decline. From within Functional Data Explorer, one can model the functional response as a function of the designed experiment factors to explore how to set them to yield the desired functional response to improve process, cut costs and get product to market faster.
Score Plot and FPC Profiler for functional data analysis
