Inventors
Morgan, J.A., Lekivetz, R.A., Jones, B.A. and King, C.B.
Patent Number
U.S. Patent 11,216,603
Date Granted
01/04/2022
Description
A computing system receives a request for a computer-generated design of an experiment. A design space is defined by candidate inputs for each factor of the experiment. The system receives a disallowed combination indication indicating a user-defined disallowed combination for the design space. The disallowed combination constrains a first set of values from a first set of candidate inputs from being assigned to the first factor if the second factor is assigned one of a second set of values from a second set of candidate inputs. The system determines additional constraint(s) on computer generation of the design. The system evaluates if a user-defined model can be generated according to the disallowed combination and the constraint(s). The system generates a computer suggested modification of the user-defined model such that the design can be generated according to the computer suggested modification.
