Inventors
Lekivetz, R.A., Morgan, J.A., Jones, B.A. and King, C.B., SAS Institute Inc, 2021. Tool for optimal supersaturated designs. U.S. Patent 11,125,655.
Patent Number
Date Granted
09/21/2021
Description
A computing device receives a request for a design of an experiment. The device generates a data representation of a matrix Y that defines a supersaturated design for the design of the experiment. The generating the data representation is by: generating a data representation of a matrix X according to an obtained design; computing an indication of correlation between effects of factors of a matrix Y; and generating, based on the indication of correlation, the data representation of the matrix Y that is the transposition of the matrix X or is the transposition of a matrix X*. The matrix X* is a first subset of the matrix X such that the transposition of the matrix X* represents a same number of factors as the transposition of the matrix X. The device outputs a setting for each test condition of the supersaturated design for the experiment.
