Inventors
Jones, B.A., Lekivetz, R.A., Morgan, J.A. and King, C.B.
Patent Number
U.S. Patent 10,803,214
Date Granted
10/13/2020
Description
A computing device receives a request for a design of an experiment. The design comprises test cases with test conditions for testing factors for the experiment. The device receives a value for a parameter of multiple parameters for the design. The multiple parameters indicate a total number of test cases for the design, a total number of factors for the design, and a total number of groups for grouping factors. The device generates a value for each of one or more other parameters of the multiple parameters such that the design is a supersaturated design. The device generates, based on the first value for the first parameter and the value for each of the one or more other parameters, the supersaturated design for the experiment that is a design that distributes each of the factors into one of the groups. The device outputs an indication of the supersaturated design.
