Patents
Optimization under disallowed combinations
Inventors
Joseph Morgan, Yeng Saanchi, Laura Lancaster, Christopher Gotwalt, Caleb King, Ryan Lekivetz
Patent Number
US-11194940
Date Granted
12/07/2021
Description
A computing system determines a design space for designing a design system. The computing system receives a request to identify input(s) that will provide a response of the design system that advances a user-defined goal for the design system. The computing system, responsive to the request to identify input(s), generates a design for the design space that provides design cases for generating the response of the design system and obtains responses of the design system generated for multiple design cases of the design for the design system. The computing system selects at least one design case based on obtained responses of the design system for the multiple design cases, and based on the at least one design case, outputs an indication of suggested input(s) for the design system. The suggested input(s) advances the user-defined goal for the design system and is not disallowed according to disallowed combination(s).
