Inventors
Lekivetz, R.A., Jones, B.A., Rhyne, J.D. and Morgan, J.A.
Patent Number
U.S. Patent 12,175,166
Date Granted
12/24/2024
Description
A computing device receives a request requesting a screening design for an experiment. The device obtains factors for screening. A first factor has a first set of candidate inputs comprising at least two candidate inputs for allowable inputs in the experiment. A second factor has a second set of candidate inputs comprising at least three candidate inputs for allowable inputs in the experiment. The device receives an indication of a run size. The device generates the screening design by assigning, based on the run size, the first factor to a two-level group that only allows at most two allowable inputs for the first factor in the experiment. The device generates the screening design by assigning, based on the initial run size, the second factor to a three-level group that only allows at most three allowable inputs for the second factor in the experiment. The device outputs the screening design.
