Patents
Mixed-level screening design construction and graphical user interfaces
Inventors
Lekivetz, R.A., Rhyne, J.D. and Morgan, J.A.
Patent Number
U.S. Patent 12,164,845
Date Granted
12/10/2024
Description
A computing device receives a request requesting a screening design for an experiment. The device obtains, for the screening design, factors for screening in the experiment. A first factor is a categorical factor with a first set of candidate inputs comprising at least three candidate inputs in the experiment. A second factor is a continuous factor with a second set of candidate inputs comprising candidate input options within range(s) for the second factor. The device receives an indication of a run size that is a user-requested quantity of runs for the screening design. The device generates the screening design based on the run size. The device outputs the screening design. The screening design comprises runs of a quantity based on the user-requested quantity of runs for the screening design. The runs comprise the first set of candidate inputs and at least three inputs of the second set of candidate inputs.
