Patents
Interactive visualization tool for designed experiments
Inventors
King, C.B., Morgan, J.A. and Lekivetz, R.A.
Patent Number
U.S. Patent 10,386,271
Date Granted
08/20/2019
Description
The computing device receives information representing a design of an experiment. The design of the experiment comprises a plurality of test cases. Each element of a test case of the design is a test condition for testing one of factors for the experiment. The computing device generates a graphical representation based on the information. The graphical representation comprises a plurality of axes for respective ones of factors used in a fractal sequence. Each of the plurality of axes has two endpoints comprising a first endpoint that corresponds to a first level of a respective factor, and a second endpoint that corresponds to a second level of the respective factor. The computing device plots, on the graphical representation, data corresponding to one or more test cases of the plurality of test cases. The computing device displays an interactive graphical user interface comprising the graphical representation with the plotted data.
