Inventors
Jones, B.A., Morgan, J.A., Bailey, M.W., Rhyne, J.D., Lekivetz, R.A. and King, C.B.
Patent Number
U.S. Patent 12,475,270
Date Granted
11/18/2025
Description
A computing device receives user input for a design of an experiment. The user input indicates respective factor identities for factors in the design of the experiment, respective response identities for responses to options for the factors in the design, and a user-defined objective for the one or more responses. Additionally, based on the user input, the computing device displays a subset of a set of multiple model types and a user-definable amount of design runs for the design. Each design run presents settings according to the design for each of the factors. The computing device also receives settings indicating a user-selected model type from the subset and a user-defined amount of design runs, and based on the settings, selects one or more design construction criteria for generating the design. The computing device then generates the design according to the design construction criteria.
