Inventors
Lekivetz, R.A., Morgan, J.A., King, C.B. and Jones, B.A.
Patent Number
U.S. Patent 11,561,690
Date Granted
01/24/2023
Description
A computing device receives a request for a design of a combinatorial test for a test system. The device receives a run indication of a total quantity of test cases for the design, a factor indication of a total quantity of factors, and/or a strength indication for a covering array. The device generates an updated design by: selecting test case(s) to remove from a first design; or adding test case(s) to the first design. The first design comprises a set of test cases that represent the covering array according to the strength indication. The updated design is constrained to the total quantity of test cases as indicated by the run indication. The device outputs a respective setting for each test condition for at least one test case of the updated design for testing the test system.
