Inventors
Lekivetz, R.A., Morgan, J.A., King, C.B., Jones, B.A., Bailey, M.W. and Rhyne, J.D.
Patent Number
U.S. Patent 11,699,000
Date Granted
07/11/2023
Description
An apparatus includes a processor to: generate variants of an experiment design based on varied parameters; for each variant, estimate terms based on the model, and derive an optimality value; present a table of the variants including a column for each varied parameter and a column for the optimality value, a row for each variant, and a bar graph for each column depicting a distribution of the values therein; present function controls operable to select a function to perform on row(s) of the table in response to selection of a bar of a bar graph of a column; in response to selection of a function, change the current function to the selected function; and in response to a selection of a bar of a bar graph of a column, perform the current function on row(s) based on instances of the value associated with selected bar.
