Inventors
Morgan, J.A., Jones, B.A. and Lekivetz, R.A.
Patent Number
U.S. Patent 10,296,680
Date Granted
05/21/2019
Description
An apparatus may include a processor caused to: receive indications of selection of experiment designs to compare; receive indications of selection of a set of terms to include in the comparison; for each experiment design, generate a corresponding term correlation graph of a set of term correlation graphs, wherein: the correlation graph comprises horizontal and vertical axes along both of which the set of terms are arranged, at each intersection within the graph, a degree of correlation between terms is indicated with a visual indicator selected from a set of visual indicators, the set of visual indicators is assigned an order that corresponds to a range of degree of correlation, and the range is divided into a set of contiguous sub-ranges, and each visual indicator corresponds to one of the sub-ranges; and present at least two correlation graphs of the set of correlation graphs at adjacent locations on a display.
