New to using JMP? Hit the ground running with the Early User Edition of Discovery Summit. Register now, free of charge.
Register
for our Discovery Summit 2024 conference, Oct. 21-24, where you’ll learn, connect, and be inspired.
Practice JMP using these webinar videos and resources. We hold live Mastering JMP Zoom webinars with Q&A most Fridays at 2 pm US Eastern Time. See the list and register. Local-language live Zoom webinars occur in the UK, Western Europe and Asia. See your country jmp.com/mastering site.
ID new JMP 17 capabilites, including JMP extrapolation control
Customize Profiler appearance
Share Profilers as HTML
Use the Interaction Profiler to show or hide interaction plots that update as you update the factor values in the Prediction Profiler
Use the Surface Profiler to produce a surface plot for the fitted model
Use the Simulator in the profilers to define random inputs, run simulations, and produce output tables of simulated values.
Use the Design Space Profiler to to explore the impact of factor limits on the expected rate of future runs passing response specifications (in-spec rate)
Examine Contour Profiler plots of response contours for two factors at a time
Questions answered by @andreacoombs1 at the live webinar:
Q: When we were resetting the factor grid, did the numbers 41 indicate 41 levels for each factor?
A; Yes.
Q: How do you determine SD for the simulation?
A: When you're doing simulation, standard deviation comes up in different ways. You have to determine what standard deviation to use when interjecting random noise around each of your factors when doing the simulation. JMP proposes standard deviations, but you, as a subject matter expert, can modify them. For example, you may know about some ability in terms of temperature control on your equipment and want to to access process knowledge and some historical data to help you determine what SD to choose.
Q: How do you change the properties before sharing the profiler?
A: Alt/Click on the red triangle pops up all properties. Alt/Click works on all JMP reports. Quick Reference Guide contains many shortcuts like this for Mac and Windows.
Q: Can Gaussian Process model in JMP handle categorical factors?
A: No, neither JMP nor JMP Pro or Standard will categorical Y response. @PatrickGiuliano clarified this after the session. However, X assigns the columns to use as explanatory variables for Gaussian Process. Categorical variables are allowed in JMP Pro when the Fast GASP option is specified.
