Check out the JMP® Marketplace featured Capability Explorer add-in
Practice JMP using these webinar videos and resources. We hold live Mastering JMP Zoom webinars with Q&A most Fridays at 2 pm US Eastern Time. See the list and register. Local-language live Zoom webinars occur in the UK, Western Europe and Asia. See your country jmp.com/mastering site.
Organizing and Getting the Most from JMP® Tables
See how to:
  • Create, format and navigate rows and columns from data grid and table panel
  • Use column properties to set data types (numeric, character, row state, expression) and modeling types (continuous, ordinal, nominal, multiple response, unstructured text, vector)
  • Understand the way JMP analyzes data based on data and modeling types
  • Use multiple response character data; hide and/or exclude rows and understand what each means
  • Use red triangle hot spots to sequentially disclose analysis and formatting options
  • Group table script to organize them in table panel
  • Format columns
  • Understand the Distribution column exception related to incorrect data or analysis type
  • See how JMP graphically links multiple response data on some graphs to show relationship between values
  • Use shortcuts to move between graphs and reports
  • Save replayable analysis scripts to data table panel
  • Add metadata (notes, list check, value labels, value ordering, formula, formula preview results)  to a group of columns
  • Recode in place to new column; save recode formula to auto-update column when new observations are added; group similar values to same recoded value; recode to value labels to simplify graphs
  • Subset rows from graph to new unlinked data table; use data view to subset rows linked to data table; exclude data from report using local data filter; label individual rows for displaying in all graphs
Note: Q&A included at times 10:52, 34:35 and 42:21.
In this short video, Alisa Hunt-Lowery shows how to compare data tables using the JMP 16 enhanced interface:
Resources
Comments
Thank you @alisa_h_lowery  for this instructive video!
I particularly liked your demonstration of the recode to value labels feature:
I find this much easier than using the old dialogue entry fields  in the Col properties > Value labels option since this way each value label has to be added one at a time, whereas this newer way, it can all be done at once.
@PatrickGiuliano
@PatrickGiuliano glad you liked it!  I love how JMP is always making our lives (& analysis!) more streamlined all the time! I think that came out in V14!
