New in JMP Clinical 18
JMP Clinical 18 incorporates performance efficiencies. plus new, updated and re-introduced reporting capabilities. You can suggest changes to JMP Clinical and all JMP products using the Wish List.
- Chapters
- descriptions off, selected
- captions settings, opens captions settings dialog
- captions off, selected
- en (Main), selected
This is a modal window.
Beginning of dialog window. Escape will cancel and close the window.
End of dialog window.
This is a modal window. This modal can be closed by pressing the Escape key or activating the close button.
See how to use:
- Updated Algorithmic FMQ (aFMQ) Risk Report
- Re-introduced and updated: Risk Based Monitoring reporting and graphs
- Re-introduced Visit Order Report
- Re-introduced Patient Recruitment Report
- New Drug Induced Liver Injury (DILI) Report
- Comprehensive review of all the clinical trial data related DILI with analysis and plots influenced by FDA guidance documents
- New Subpopulation Builder
- Create complex rule/logic-based queries to build sub-populations (patient populations
- New Clinical Data Mapping Tool
- Add-in that is automatically registered upon installation and can save steps and results to a JMP Workflow
- New JMP Clinical Recoder
- Add-in that is automatically registered upon installation and performs a simplified recode capability
Questions answered by Rebecca Lyzinski @rlyzinski and Chris Kirchberg @Chris_Kirchberg at the live webinar.
Q: Have the Snapshot Reports changed in JMP Clinical 18?
A: We still do a record-by-record comparisons, display lists of new and modified records, and add a flag list of those to reports. However, we no longer include a domain view report for comparisons. See video below.
- Chapters
Q: How the Sankey plots are generated, SAS code or JMP Script?
A: The Sankey plots are generated with a JMP Script. JMP Clinical is now completely written using JMP instead of SAS.
Q: If I modify the ADSL and add custom variables, will that show up in the list of variables when using the Subpopulation builder?
A: Any variables in the datasets will appear in the filters as long as they were present when you added or refreshed your study.
Q: Can filtering options be saved and shared?
A: The filters built using the subpopulation builder can be saved. Currently, the only way to share the filters are to copy the underlying text file and send it to others.
Q: Can these reports be generated with .sql, .sas, and/or .csv files as well as .jmp files?
A: JMP Clinical will accept JMP files, SAS files, and transport files for datasets. So .jmp, .sas7bdat, or .xpt files. We are adding support for JSON files in JMP Clinical 18.1.
Q: Is the subject filter the only one available, can you add filters from other datasets?
A: You would likely use Subpopulations, filter by that, and then save.
Q: is there a way to create a report comparing Subpopulations?
A: If you select something, for example from a subpopulation, you can create a population flag, but it is not retained for a new data set.
Resources
- Mastering JMP video on Workflow Builder.
- JMP Clinical User's Guide
Upcoming Events
Tips and Tricks – From Tables to Graphs and Beyond
Feb 28JMP includes shortcuts and capabilities that can streamline your JMP analyses and reporting. Learn interesting shortcuts and tips, including tho... -
Disentangling and Organizing Wide Data
Feb 14Do you have wide data where each observation occupies a single row, and where you have individual or groups of columns useful for making predictions?... -
EMEA Mastering JMP: Understanding and Modeling Response Curves
Jan 31Learn how to analyze sequential measurement data where measurements you want to analyze as responses are not single points, but a range of points pres...
