Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
Easy DOE: Peek Under the Hood to Discover How Your Process Works
Presented in English
Published on ‎11-21-2025 12:38 PM by Community Manager Community Manager | Updated on ‎07-30-2026 12:50 PM
Video using JMP 19 was posted in March 2026.
Designed experiments are powerful, structured tests that reveal how your factors truly drive the responses you care about. Using Easy DOE Guided Mode, you can build and explore experiments effortlessly using an intuitive sequence of tabs, interactive profilers, and automated reports. Whether you're new to DOE or a seasoned pro, this session will give you tools to explore your processes, make informed decisions, and communicate results effectively.
  1. Do you have a major issue needing resolution?
  2. Can you measure the issue with accuracy and resolution?
  3. Do you have a list of potential factors that might impact your issue?
  4. Can you control these factors?
  5. Can you add cost/waste as a response if relevant?
See how to:
  • Start with the end: Present DOE results interactively to decision makers for faster, smarter decisions.
  • Follow the DOE process: 6 core steps, plus Easy DOE’s 7th step, Report.
  • Understand your factors and responses: Make confident choices for your designs.
  • Design experiments: From simple main-effect screening to response surface designs capturing interactions and curvature, let JMP create your design.
  • Analyze your DOE results: Quickly interpret insights and decide on next steps.
  • Export your reports: Share polished, ready-to-use summaries in seconds.
This webinar covers: JMP Easy DOE Guided Mode
Data from typical process used in demoData from typical process used in demo
Resources
Start:
Fri, Mar 20, 2026 02:00 PM EDT
End:
Fri, Mar 20, 2026 03:00 PM EDT
Labels (1)
0 Comments
