Learning Resources
Building and Understanding Predictive Models
Whether you call it model fitting, data mining or machine learning, JMP Pro has tools for you. JMP Pro makes it easy to build a variety of models all at once in Model Screening, and determine the best type of model for your problem, easily compare different models, and organize models and output models in C, Python, Javascript, SQL, and SAS.  Discover how to use the JMP’s decision tree methods, JMP’s Generalized Regression platform that uses modern regression techniques with penalized methods, and Neural Network platforms to perform data mining and root cause analysis.
(view in My Videos)
This is part of the Get Going with JMP series.
Resources:
