Learning Library
How can I create and save customized interactive drill-down graphs in JMP?
In JMP,  you can add a thumbnail of a graph or an image of  elements on a  graph built using Graph Builder.  These thumbnail, customized, interactive graphs are called graphlets.  You can also nest graphlets.
Start by creating a graph in Graph Builder.  This is your baseline graph. Copy the script by saving it to your clipboard using SAVE SCRIPT > TO CLIPBOARD,  and then paste it as a graphlet into a baseline graph.  After you have added the graphlet, you can put your cursor over an element in the baseline graph to see a thumbnail preview of the graphlet for that element.
To nest graphlets, copy them starting from the lowest level into your clipboard using SAVE SCRIPT > TO CLIPBOARD, then paste into the next highest-level graph, until you have the final graph.   Then,  save the final graph using SAVE SCRIPT > TO DATA TABLE.  Remember to then save the table.  When you open the table, you can run the script from the Tables Panel, see the highest-level graph and drill sequentially into the lower-level graphs.
See a short example that also includes adding and saving a data filter.
(view in My Videos)
See a full Mastering JMP video on how to create custom drill-down graphs.  Work through documentation and examples about creating graphlets and other customizable hover graphs.
Comments
Hover Labels made easy!
Great video!
