Learning Library
Creating Formulas Hands-on Activities Solutions
These hands-on activities allow you to practice creating formulas using the formula editor in JMP. This post contains the creating formulas hands-on activities, the data, and a PDF file of these solutions in English.
1. A book publisher wishes to know if there are more defective books printed on Monday or Friday. Open the Publishing data table and add two formula columns to create the following graph.
a) Open the Publishing data table.
b) Right-click at the top of the Date column and select New Formula Column > Date Time > Day of Week Name.
c) Select both the Books Printed and Defective Books columns, then right-click at the top of the columns and select New Formula Column > Combine > Ratio (reverse order).
d) Select Graph > Graph Builder.
e) Drag Defective Books/Books Printed to the Y drop zone.
f) Drag Day of Week to the X drop zone.
g) Select the Box Plot element.
h) Click Done.
No patterns across days are evident.
2. As part of a manufacturing process, cells are grown in bioreactor tanks whose environment is regulated by automated sensors. The cell density is recorded every 12 hours. Three replicated measurements are taken. The growth since the beginning of the run is expected to follow an exponential growth and decay curve. Open the Growth Control data table and add two formula columns to build the following graph.
a) Open the Growth Control data table.
b) Select the three columns Density 1, Density 2, and Density 3.
c) Right-click at the top of the columns and select New Formula Column > Combine > Average.
d) Rename this new column to Average Density.
e) Right-click the top of the Date column and select Insert Columns.
f) Name the new column Duration.
g) Right-click the top of the Duration column and select Formula.
h) Click Date, then click the subtraction button, then click Date again.
i) With the second Date still selected, select Row > Subscript.
j) Type 1.
k) Select the whole formula and click the division button.
l) Select Date Time > In Hours.
m) Type 1.
n) Click OK.
o) Select Graph > Graph Builder.
p) Drag Average Density to the Y drop zone.
q) Drag Duration to the X drop zone.
r) Click Done.
