Browse apps to extend the software in the new JMP Marketplace
Using Formulas and the Formula Editor
See how to make and edit formulas in JMP
See how to use JMP's powerful, easy-to-use Formula Editor to create columns with values computed by a formula and store the formula as part of column information. Learn how to build formulas that are simple assignments of numeric, character or row state constants, or complex evaluations based on conditional clauses. See how formulas are linked to, or dependent on, values in other columns and how those values will be automatically recomputed when values change.
This is part of the Get Going with JMP series.
Resources:
Comments
NaomiReyes
Hello, "Unit Data" table missing from .zip. Lot 2 formula column missing from Process Data table, but I was able to directly code from your screen. Thanks! (Using JMP 17.1)
