See some of the keygraphic enhancements added with JMP 16.
- Dynamic Graph Axis Labels - Axes with date/time will transform dynamically to show the appropriate level of detail depending on the zoom level
- Row Order Flag - New quick and easy to build run chart using Row Order flag
- Cumulative Sum - New Cumulative summary statistic for bars and lines
- Ruler Tool - New Ruler Tool is used to measure distances between points on a graph
- Box Plots - Enhanced to Size By a variable and Notch for the median confidence interval.
Other enhancements include:
- Points can have locally defined marker column or marker expression
- Shape elements can have a locally defined custom shape fil
- There is a new quick and easy to build run chart using Row Order flag
- Contour Legend has been updated to align with Contour platform and there is an option to use triangles to indicate above/below
- New density random jitter option
- New Unselected Faded option for filled areas in Fill Selection Mode (see Preferences)
- New "Show" submenu with options for show/hide of axes and axis titles and existing show items (Title, Subtitle, Legend)
- Heat maps in Graph Builder now supports Hexagonal binning
