To change the format of values and their confidence intervals in Prediction Profilers or other Graphs, change the format of the response column in the associated data table and then select redo Analysis using the red triangle in the report.
Using the Body Fat Sample Data table I have the Profiler at the bottom of my Fit Model report and I want to format the Decimal places To a Width of 2, like .01, (only showings two places after the decimal point).
- In your data table, right-click the response column and select Column Info. In this example, it's Percent Body Fat, the 1st Column.
- Next to Format, We can Change the Formatting and Values; I'm going to choose Fixed Decimal, 10 Wide at 2 Decimals.
- We can Drop down and reformat multiple ways.
- Select Apply then OK to close the Column Info Window.
- Under the Red Triangle of the Report Select Redo - Redo Analysis
