  • Sign-in to the JMP Community will be unavailable intermittently Dec. 6-7 due to a system update. Thank you for your understanding!
  • JMP 19 is here! Learn more about the new features.
Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
Screening Designs in JMP 17
Published on ‎11-07-2024 03:31 PM by Community Manager Community Manager | Updated on ‎11-07-2024 05:41 PM
Screening designs are among the most popular designs for industrial experimentation. Typically used in the initial stages of experimentation, they examine many factors in order to identify those factors that have the greatest effect on the response. The factors that are identified are then studied using more sensitive designs. Because screening designs generally require fewer experimental runs than other designs, they are a relatively inexpensive and efficient way to begin improving a process.
Start:
Fri, Dec 2, 2022 02:00 PM EST
End:
Fri, Dec 2, 2022 03:00 PM EST
Labels (1)
0 Comments
