Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
New in JMP 17 and JMP Pro 17 - Some Highlights ORIGINAL ENGLISH VERSION
Presented in English
Published on ‎11-20-2024 05:05 PM by Community Manager Community Manager | Updated on ‎10-21-2026 01:38 PM
New Features Everyone Can Use
  • Workflow Builder - JMP Macro Recorder (see video below)
    • Collect and save analysis steps
    • Replay all steps at once
    • Replay single steps
    • Add steps to Workflow
    • Share workflow
    • Create Workflow package
  •  Tables Menu Operations Preview - Preview Before You Click OK (see video below)
    • Concatenate Tables
    • Join Tables
    • Sort Table
    • Split Tables
    • Stack Tables
    • Subset Tables
    • Table Summary
    • Transpose Tables
    • Update Table
  • Tables Preview for StackTables Preview for StackTables Preview for Stack
  • Interactive JMP Search - Search In Context During Analysis (see video below)
    • JMP Menu Items
    • Red Triangle Menu Items
    • Sample Data Table Names
    • Sample Data Script Names
    • Teaching Scripts
    • Help Tutorials
    • JMP Scripting Index
    • JMP Document Library
Search JMP to get info and path for the analysisSearch JMP to get info and path for the analysisSearch JMP to get info and path for the analysis
  • Custom Ordering - Create Custom Variable Order and Save as Preference (see video below)
  • Create and Save Preferences Directly from Analyses
  • Feature Version Display - ID When Features Were Introduced & Set Feature Version Filters (see video below)
  • Plotting Multiple Responses in Graph Builder (see video below)
  • Display Tabular Data in Graph Builder - Reference Lines and Statistics (see video below)
DOE Features for Experimenters
  • Easy DOE - Guided & Flexible Modes for Different Levels of Experience (see video below)
  • Design Explorer - Explore Many Design Options (see video below)
Quality and Process Improvement
  • Design Space Profiler - Optimize Process for Your Design Space (see video below)
  • MSA Design - MSA Design Assistance (see video below)
  • MSA Improvements - Integrating EMP graphs w/ Gauge R&R tabular summaries (see video below)
  • Process Screening Improvements (see video below)
MSA Design interface lets you ID factors, factor levels, randomization schemeMSA Design interface lets you ID factors, factor levels, randomization schemeMSA Design interface lets you ID factors, factor levels, randomization scheme
JMP PRO FOR ADVANCED USERS
  • Model Random Effects and Non-Normal Distributions (see video below)
    • Generalized Linear Model - working with non-normal distributions such as Count (Poisson) and Proportions (Binomial)
    • Mixed Model - working with random effects such as Blocking
    • GLMM - Generalized Linear Model + Mixed Models
  • Spectral Data Analysis (Functional Data Explorer Wavelets) (see video below)
  • Model Screening Improvements (see video below)
Questions aswered by Mike Anderson @MikeD_Anderson during the live webinar:
Q: In Workflow Builder, if you add more data to the data table, and rerun the workflow, will the new summary statistics/analyses get updated with new charts/values?
A: Yes.
Q: Can we use the recorded workflow on a new set of data?
A: Yes.  If the data table it’s expecting isn’t open it will prompt you for a new one.  It will also prompt for any missing columns in the analysis.
Q: Can we import the JMP16 preferences to JMP17?
A: Yes, they’re brought in automatically when you install your new license to 17.
Q: Does JMP use and icon to mark platforms that have moved menu position in the current release?
A: No, it uses and icon to mark new capabilities/analysis platforms, not platforms that have moved menu location.
Q: Can I export Profilers so that non-JMP users can interact with the scenario building?
A: You can save to an HTML 5 report, JMP Public, JMP Live (if you license it).
Q: Re; MSA, will you define "gauge"?  Is that the equipment or device you are using to measure the part?
A: It’s the tool used to make a measurement.  The term comes from classical manufacturing where you have calipers and gauges.
Q: Can MSA show Anderson-Darling or something to indicate normal conformance of data?
A: That’s available as a test in the Distribution platform.  You can learn more about it.  The info on that test is found in JMP 17 documentation, but the test has been in there for a while.
Q: With the new capability of Graph Builder to handle data with multiple Response structure, was the Rows/Row Selection/Name Selection in Column function updated to "collect" multiple labels in the label column? Then the label column could be used like the multiple-response column that Hyde used in his example.
A: Yes. Multiple response data maps back to the data table and selects the rows that contain the selected response.  So those features will work as normal.
Resources
Start:
Wed, Oct 19, 2022 05:47 PM EDT
End:
Wed, Oct 19, 2022 06:47 PM EDT
0 Comments
