Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMP® Marketplace
Live Course - JMP® Pro: Analyzing Curves and Profiles Using the Functional Data Explorer - Aug. 12 - 15 | 9:00 a.m. - 12:30 p.m. ET
Published on ‎05-09-2024 03:50 PM by Staff | Updated on ‎06-25-2024 11:18 AM
4 Day Course
Monday, August 12 | 9:00 a.m. - 12:30 p.m. ET
Tuesday, August 13 | 9:00 a.m. - 12:30 p.m. ET
Wednesday, August 14 | 9:00 a.m. - 12:30 p.m. ET
Thursday, August 15 | 9:00 a.m. - 12:30 p.m. ET
This course helps you recognize and model functional data using JMP Pro. It teaches you to use the data as a response, such as the outcome for a designed experiment, or as new covariates or features, such as in a multivariate analysis.
Functional data are defined as a function, profile, or curve. They are a series of observations over time or any other continuous variable. These data can be modeled so that changes in the shape can be associated with changes in other variables.
Learn how to:
  • Recognize functional data and their uses.
  • Preprocess data to suit the functional data analysis.
  • Select a model of the functions.
  • Obtain optimal representations of the functions.
  • Use the new representations as the responses in the analysis of a designed experiment.
Who Should Attend:
Directors, managers, engineers, scientists, technicians, and analysts who work with functional data to design, develop, improve, and optimize a product or process
Duration: 4 half-day sessions
Registration Fee: $400 US
Learn more, and register, at JMP® Pro: Analyzing Curves and Profiles Using the Functional Data Explorer.
Start:
Mon, Aug 12, 2024 09:00 AM EDT
End:
Thu, Aug 15, 2024 12:30 PM EDT
Labels (1)
0 Comments
