Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMP® Marketplace
Live Course - JMP®: Designing and Building a Complete JMP® Script - Jun. 10 - 13 | 9:00 - 12:30 p.m. ET
Published on ‎05-09-2024 03:43 PM by Staff | Updated on ‎06-25-2024 11:17 AM
4 Day Course
Monday, June 10| 9:00 a.m. - 12:30 p.m. ET
Tuesday, June 11 | 9:00 a.m. - 12:30 p.m. ET
Wednesday, June 12 | 9:00 a.m. - 12:30 p.m. ET
Thursday, June 13 | 9:00 a.m. - 12:30 p.m. ET
This course teaches you how to approach writing a new script in a methodical way. A realistic case study is used to illustrate the typical steps. A separate case study is developed in the course exercises. A storyboard showing the results from the script, the JMP objects that will be used by the script, and the steps necessary for the script to carry out is developed at the beginning of the course, and it is further developed throughout the course. The results are used to determine the necessary data, so the next step is identifying the analysis variables and their original data stores. Techniques to import data, cleanse and harmonize data, and derive new variables complete the first half of the course. The second half of the course teaches how to script the conversion of the variables into results. JMP objects are used to create a working framework. Each object is then customized or extended as necessary. Optional results or computations are captured in a user dialog to finish the script.
Learn how to:
  • Design and build a script end to end.
  • Identify data sources.
  • Import data from flat files and Excel workbooks.
  • Clean and transform data.
  • Build a presentation from JMP objects.
  • Customize objects for final results.
Duration: 4 half-day sessions
Registration Fee: $400 US
Learn more, and register, at JMP®: Designing and Building a Complete JMP® Script
Start:
Mon, Jun 10, 2024 09:00 AM EDT
End:
Thu, Jun 13, 2024 12:30 PM EDT
Labels (1)
0 Comments
