  • Sign-in to the JMP Community will be unavailable intermittently Dec. 6-7 due to a system update. Thank you for your understanding!
  • JMP 19 is here! Learn more about the new features.
Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
  • Scripters Club: Managing Your JMP Add-Ins with Justin Chilton
    Presenter: Justin Chilton, JMP Software Testing Expert
    In this Scripters Club session, Justin Chilton, the developer behind the popular Add-In Manager on the JMP Marketplace, will showcase how to better organize, update, and deploy your JMP add-ins. Learn how this tool can simplify your scripting workflow and improve how you manage and share your custom solutions.
    Learn JMP Events |
    Tuesday, December 9, 2025
    Dec 10
  • Jump into DOE: Hands-on Workshop
    Jump into DOE   Date:  Wednesday, December 10
    Time: 1:00 – 2:30 p.m. ET
    Duration: 90 minutes
    Registration: FREE
    Hosted via Zoom   This workshop is designed for intermediate to advanced JMP users who are familiar with basic statistical modeling (ANOVA and regression) and are interested in learning about design of experiments (DOE) in JMP. Attendees gain a deeper understanding of DOE through demonstrati...
    Learn JMP Events |
    Wednesday, December 10, 2025
    Dec 10
  • Empezando con JMP®
    Una introducción práctica para nuevos usuarios, usuarios con licencia de prueba o cualquier persona que necesite un repaso   Regístrese ahora   Fecha:  jueves, 18 de Diciembre
    Hora: 1:00–2:00 pm ET
    Inscripción: GRATUITA   Tanto si acaba de descargar la prueba gratuita de 30 días de JMP, como si es nuevo en el software o vuelve después de un tiempo, este seminario web le ayudará a empezar a utilizarl...
    Learn JMP Events |
    Thursday, December 18, 2025
    Dec 18
  • Getting Started With JMP®
    A practical introduction for new users, trial users, and anyone who needs a refresher   Register now!     Date:  Friday, December 19
    Time: 1:00–2:00 p.m. ET
    Registration: FREE     Whether you've just downloaded the JMP 30-day free trial, are new to the software, or are returning after time away, this webinar helps you get started quickly and confidently.     This session is a great introduction to J...
    Learn JMP Events |
    Friday, December 19, 2025
    Dec 19
    Una introducción práctica para nuevos usuarios, usuarios con licencia de prueba o cualquier persona que necesite un repaso   Regístrese ahora   Fecha:  viernes 15 de Enero
    Inscripción: GRATUITA   Tanto si acaba de descargar la prueba gratuita de 30 días de JMP, como si es nuevo en el software o vuelve después de un tiempo, este seminario web le ayudará a empezar a utilizarlo de...
    Learn JMP Events |
    Thursday, January 15, 2026
    Jan 15
  • JMP 19 Enhancements to JMP Live
    JMP Live offers JMP users collaborative analytics software to share analyses from JMP to a secure, centralized hub of innovation for enterprise knowledge sharing. See how to use the new interface and capabilities in JMP Live 19 to: Include new interactive reports.Navigate the redesigned landing page and access recently viewed or updated reports.Take advantage of linked data tables that automatical...
    Learn JMP Events |
    Friday, January 16, 2026
    Jan 16
  • Utiliser des formules pour tirer le meilleur parti de vos données
    French Mastering JMP Transformez des données brutes en informations exploitables grâce à l’éditeur de formules de JMP. Extraire les informations clés des chaînes et des horodatagesCréer des formules dynamiques qui se mettent à jour automatiquementSimplifier la logique complexe avec des outils faciles à utiliser
    Learn JMP Events |
    Friday, January 30, 2026
    Jan 30
  • Data Exploration for Upstream Processing and Fermentation
    EMEA Mastering JMP Experimenting with microbial and mammalian systems brings a multitude of data; bioreactor sensor data, sampling events and growth curves all present a complicated data challenge to understand from your experiments. This session will explore the core tools in JMP you need to explore, visualise and filter your data, looking at examples of bioreactor data and cell growth curves in ...
    Learn JMP Events |
    Jan 30
  • Importing and Preparing Excel Data for Use in JMP
    JMP easily imports Excel spreadsheets into JMP tables. JMP data tables store data and user-specified information that enables graphical analysis and reporting far beyond what Excel can provide. JMP is oriented around variables, represented by columns. Each data column is a cohesive collection of values for each variable. These values share the same meaning and, therefore, the same format and other...
    Learn JMP Events |
    Jan 30
  • Importing and Structuring PDF Data
    JMP imports and analyzes the important data you collect or store in a variety of databases and formats, including PDF. Importing PDF is fairly straightforward and almost always requires cleanup. Use JMP to streamline common tasks by automating access and cleanup of multiple PDF files and reports from a variety of sources. See how to: Interactively import data from PDF files.Automate importing mult...
    Learn JMP Events |
    Friday, February 13, 2026
    Feb 13
  • Getting Started with Graph Builder
    Graph Builder is a versatile way to interactively create visualizations to explore and describe your data. Drag & drop data to predefined zones to visually identify relationships between variables. Quickly create, undo, redo, and experiment with plots that link to your data, until you find the one you want. Then, save and share your results with others. Graph Builder capabilities have increa...
    Learn JMP Events |
    Friday, February 20, 2026
    Feb 20
  • Preparing Your Data
    Often, the raw data you use is not set up for analysis and must be arranged and shaped for easy, proper graphing and analysis. The source can also be in different tables that must be joined into a master table to make full use of the information. Additionally, sometimes a summary of the data is needed or subsetting is required. JMP provides rich capabilities to reshape your data for optimal analys...
    Learn JMP Events |
    Friday, February 27, 2026
    Feb 27
  • Sharing and Communicating Results
    JMP goes beyond analyses to ensure you get correct information into the right hands at the right time. Various collaborative interfaces let you share both raw data, reports, and graphics between different stakeholders in your organization. See how to create and share: Static reports in JMP and non-JMP formats.Dynamic JMP reports that you can keep current.Dashboards of multiple reports and graphs.I...
    Learn JMP Events |
    Friday, March 6, 2026
    Mar 6
  • Basic Data Analysis and Modeling
    JMP offers a variety of ways to interactively examine and model the relationship between an output variable (response) and one or more input variables (factors).  It also offers tools for explanatory modeling to determine which variables help explain a response. See how to: Identify and interpret statistics for the distribution of data, including 1-sample t-test,  capability and tolerance interval...
    Learn JMP Events |
    Friday, March 13, 2026
    Mar 13
  • Gestion des tables de données
    French Mastering JMP Ouvrez la voie à une exploration de données plus rapide, plus claire et plus sûre. Structurez vos colonnes plus efficacementFiltrez vos données en toute simplicitéObtenez instantanément des insights
    Learn JMP Events |
    Friday, March 20, 2026
    Mar 20
  • Easy DOE: Peek Under the Hood to Discover How Your Process Works
    Designed experiments are powerful, structured tests that reveal how your factors truly drive the responses you care about. Using Easy DOE Guided Mode, you can build and explore experiments effortlessly using an intuitive sequence of tabs, interactive profilers, and automated reports. Whether you're new to DOE or a seasoned pro, this session will give you tools to explore your processes, make infor...
    Learn JMP Events |
    Mar 20
  • Enhancing Analysis Pipelines with Workflow Builder and Basic Scripting
    Do you find yourself repeatedly performing the same data analysis steps—importing, cleaning, transforming, and visualizing—every time you receive new data? Are you looking for a way to make your analyses consistent, reproducible, and easier to share with your team—without writing code? Do you want to automate and streamline your analysis process, enabling you to focus more on insight? See how to: ...
    Learn JMP Events |
    Friday, March 27, 2026
    Mar 27
  • Analyzing Reliability for Non-Repairable Systems
    JMP lets you identify vulnerabilities and make reliability lifetime predictions on your products and components.  See how to analyze non-repairable systems. See how to: Understand the kinds of problems are addressed by reliability tools.Consider issues addressed by reliability analysis.Understand censoring used in analysis.Plan the test.Analyze reliability with or without multiple failure causes.A...
    Learn JMP Events |
    Friday, April 17, 2026
    Apr 17
  • Understanding Variation and Assessing Process Behavior
    A process that is off target, too variable or out of control can result in delays, rework, or defects, which in turn often lead to higher costs and unsatisfied customers. Because of this, it’s important to understand and quantify the sources of variation within a process. See how to: Distinguish between common cause and special cause variationAssess the health of a process, whether it’s for a few ...
    Learn JMP Events |
    Friday, May 1, 2026
    May 1
  • Developer Tutorial: New Patient Safety Reports in JMP Clinical
    This session is for JMP Clinical users and anyone from the clinical trials community interested in new reports relating the timing of adverse events to patient safety.   Do you run clinical trials or work at a sponsoring or regulatory agency supporting clinical trials? Is patient safety related to new or improved medications critical to your organization’s success? Do you need to understand the po...
    Learn JMP Events |
    Friday, December 5, 2025
    A practical introduction for new users, trial users, and anyone who needs a refresher   Register now!     Date:  Friday, December 5
    Registration: FREE     Whether you've just downloaded the JMP 30-day free trial, are new to the software, or are returning after time away, this webinar helps you get started quickly and confidently.     This session is a great introduction to JM...
    Learn JMP Events |
  • Jump into Control Charting: Hands-on Workshop
    Jump into Control Charting   Date:  Wednesday, December 3
    Registration: FREE
    Hosted via Zoom   This online workshop is designed for intermediate to advanced users with at least one year of JMP experience who would like to dive deeper into quality. Attendees learn the basics of statistical process control.   Register now!   If you have any questions about ...
    Learn JMP Events |
    Wednesday, December 3, 2025
  • New in JMP Student Edition 19
      JMP Student Edition 19 is available now and is packed with exciting new features. This webinar reviews a selection of new features relevant to instructors and researchers, from interface improvements to entirely new analysis platforms, including: Data table enhancementsGraph Builder improvementsJMP Notebook interface for coding with JSL and PythonBayesian optimizationPropensity score methods fo...
    Learn JMP Events |
  • DOE Club Q4 2025
    This Club is is a participant-driven meeting designed to encourage attendee involvement and knowledge sharing. Join us for these lightly structured discussions to share your ideas and learn more about Design of Experiments (DOE). What can you expect? Quarterly meetingsLightly structured discussions about design of experiments in JMP.Experts and novices are welcome. Be ready to share and ready to l...
    Learn JMP Events |
    Tuesday, November 25, 2025
    A practical introduction for new users, trial users, and anyone who needs a refresher   Register now!     Date:  Friday, November 21
    Learn JMP Events |
    Friday, November 21, 2025
