Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
JMP Scripting Language for Experienced JSL Users – Part 2
Presented in English
Published on ‎11-07-2024 03:29 PM by Community Manager Community Manager | Updated on ‎04-08-2025 09:13 AM
See how to:
  • Examine tree structure
  • Use Scripting Index
  • Show properties to identify objects used in reports and messages that can be sent to objects using JSL
  • Build.dialog structures to capture user input, including button boxes, check boxes, radio boxes, freeform text edit boxes, number edit boxes, combo boxes and slider boxes
See how to:
  • Capture user input and customize graphs based on input
  • Understand difference between graph boxes and frame boxes
  • Line up boxes for vertical alignment, add text to a frame box display text on graphs, use mousetrap to select points and show coordinates on graphs, add a button box to control graphs, and dynamically create check boxes
  • Create column list boxes and list boxes
See how to:
  • Modify and operatie on values from a JMP report, including how to add columns to a report, capture report results into a log, capture a table as a matrix and capture a report as a data table
  • Automatically update reports in third-party packages, such as MS Power Point, when the data refreshes
Resources
Start:
Mon, Sep 21, 2020 02:00 PM EDT
End:
Mon, Sep 21, 2020 03:00 PM EDT
Labels (1)
0 Comments
