Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMP® Marketplace
JMP®: Custom Design of Experiments
Published on ‎01-28-2022 02:05 PM by Community Manager Community Manager | Updated on ‎02-17-2022 08:22 PM
Custom design is an approach to designing experiments that produces optimal designs for the problem you’re trying to solve, whether that’s identifying important effects, or trying to optimize one or more responses. In addition to learning about custom design in JMP, you’ll explore key design concepts including sample size and power, balance, choice of factor ranges, blocking, and design evaluation. This course is for anyone who works in discovery, research, development, and quality assurance or control, as well as Black Belts who are working on Six Sigma projects.
Learn how to
  • Use custom design for any experiment.
  • Choose appropriate criteria for optimal design.
  • Effectively and efficiently test factor effects or predict responses.
  • Augment existing experiments to address new questions.
  • Design and analyze experiments with hard-to-change factors.
  • Eliminate noise from nuisance factors.
  • Find the best factor settings to achieve desired response levels.
Duration: 4 half-day sessions
Visit the course overview to learn more and register for an upcoming session.
Start:
Fri, Apr 29, 2022 01:00 PM EDT
End:
Fri, Apr 29, 2022 04:30 PM EDT
Labels (1)
0 Comments
