Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
JMP Academic Webinar - Building, Diagnosing, and Interpreting Linear Regression Models
academic-webinar-banner.svg
Published on ‎06-16-2022 03:14 PM by Staff | Updated on ‎04-21-2025 02:32 PM
Get JMP software free for academic use at jmp.com/student
Linear regression modeling is one of the most widely used statistical tools in academic research. Applying this foundational technique effectively requires a degree of technical knowledge regarding model construction, diagnostics, and interpretation. This webinar, which is appropriate for novice to intermediate linear modelers, will help you build the technical knowledge to be able to confidently use linear modeling in your work. We'll see how to: build standard least squares regression models with a mix of continuous and categorical factors, diagnose and address common problems with regression models, and interpret model parameters appropriately.
Start:
Wed, Jul 27, 2022 02:00 PM EDT
End:
Wed, Jul 27, 2022 03:00 PM EDT
0 Comments
