Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
Fitting Repeated Measures Data using JMP Pro
Presented in English
Published on ‎11-07-2024 03:29 PM by Community Manager Community Manager | Updated on ‎11-17-2026 02:29 PM
See how to:
  • Use repeated measures to model correlation structures
  • Organize data, graph correlations, build models, compare/select the best model and test hypotheses
  • Interpret statistics related to mix models
  • Understand Toeplitz, ante-dependent and compound symmetry (equal variances) covariance structures
  • Deploy AR(1) model that assumes degradation rate constancy over time
  • Deploy Toeplitz model that has different degradation rates for different time periods
  • Deploy random coefficients (random intercept/random slope) models to model random effects
  • Interpret Repeated Effects Covariance Parameter Estimates
  • Compare models
Resources
Start:
Thu, Sep 24, 2020 02:00 PM EDT
End:
Thu, Sep 24, 2020 03:00 PM EDT
0 Comments
