Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
Developer Tutorial: Designing and Evaluating Measurement Systems Studies Prior to Implementation
Presented in English
Published on ‎11-07-2024 03:31 PM by Staff | Updated on ‎11-07-2024 05:41 PM
Note: All the capabilities shown are in JMP 17, although JMP Pro 17 is used for the demo.  The video includes Q&A and comments from the presenter Caleb King @calking about how MSA works plus plans for possible enhacements.
See how to:
  • Understand basics of MSA Design
    • MSA primary focus is on decomposing variation in product measurements into distinct sources, with the goal to reduce or elimnate one or more sources
    • The metric of interest is not an effect size (i.e. difference in mean behavior), but rather the variance contribution from a particular source
    • Underlying models are primarily random effects models or even mixed effects models if biasing terms are included
    • Nested factors are also common in MSA, but not exclusively
  • See improvements made in JMP 17
    • Better diagnostics that more closely align with MSA analytics platforms
    • Greater user interaction that allows exploration of what-if scenarios
    • Fexible Design structure interface so  users can specify nesting/crossing relationships in the design
  • Understand that diagnostics are based on simulation of variance estimates, based on the standard ANOVA approach
    • Example is a 3- factor fully crossed MSA where mean squares have known Chi-square distributions that are easily be simulated and then used to compute confidence intervals, variance proportions, etc.
  • Include nested and crossed structures
  • Make design and evaluate diagnostics for two examples
MSA Design Factor ScreenMSA Design Factor ScreenMSA Design Factor Screen
The video includes Questions ansered at the webinar by Caleb @calking, Don McCormack @DonMcCormack and Jerry Fish @JerryFish.
One person asked online if nesting would occur when testing same methods on different equipment.  They responded: Probably not, but it would ultimately depend on how the experiment was run what assumptions were made about the methods and equipment.  If you considered the equipment/method to be a random observation from a much larger population, then they may be considered nested (in some way). If you considered them from a fixed set of values (e.g., types of equipment), then they would more likely be treated as crossed.
Resources
Start:
Fri, Oct 28, 2022 02:00 PM EDT
End:
Fri, Oct 28, 2022 03:00 PM EDT
0 Comments
